Old 06-09-2011, 09:13 PM
JimWoo50 JimWoo50 is offline
Default alt. tension arm bolt ?
I have tried various 5/16 bolts; grade 8, fine thread and can't get anything to thread into my 0-320 engine case to hold the tension arm on. Is this a special bolt?
Old 06-09-2011, 09:16 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Like almost all bolts on the Lycosaurus, it is a course thread.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-10-2011, 12:27 AM
PCHunt PCHunt is offline
Default Yep
Of course it's a coarse thread.... it's Lycoming!
Apolgies, Paul. I just couldn't resist!
Old 06-10-2011, 05:55 AM
Mel's Avatar
Mel Mel is offline
Coarse thread bolts are almost always used when screwing into a casting.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-10-2011, 07:49 AM
krw5927 krw5927 is offline
When I was looking for this same bolt, it seemed the proper one to use was MS20074-05-06. It has a hole in the cap for safety wire. PlanePower includes them in their kits if you buy from them (which I didn't), and Skytec specifies their use for the stabilizing bracket between the starter and alternator.
http://www.plane-power.com/images/In...L12-EI60_B.pdf
http://www.skytecair.com/Hardware.htm
Problem is these dang bolts are so hard to find, and once I did find them I nearly choked when I saw the price. Some folks wanted upwards of $10 apiece. After an extensive search I ended up finding them for a reasonable price (drop shipped from Cessna) but had to buy 10, which is way more than I'll ever need. PM me if you need some.
Kurt W.
RV9A
FLYING!!!
Old 06-10-2011, 10:44 AM
az_gila's Avatar
az_gila az_gila is offline
My Lycoming parts manual uses the number STD-1817, and Cessna says it has a superceded number of LW31H0.75
Using the new number, www.aeroinstock.com has it for $3.54
http://www.aeroinstock.com/products/...ail/index.html
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-10-2011, 12:53 PM
Yep, that's about right. Since mine came direct from Cessna, they were about $2.50 apiece. But, only sold in 10-packs.
Kurt W.
RV9A
FLYING!!!
