Old 06-09-2011, 08:51 PM
bill@fusion4.net's Avatar
bill@fusion4.net bill@fusion4.net is offline
Unhappy Big FUBAR with NACA vent
Well, there is the saying measure twice, cut once. I think I need to amend it tonight and say OPEN YOUR EYES and THINK before measuring the first or second time.
I layed out and cut my NACA vent backwards on my left side for rear vents. (After the skin was on the tail)
https://picasaweb.google.com/lh/phot...eat=directlink
-- Followed the directions, but just getting a link for the photo sorry it did not embed.
Options as I see them:
1. Replace entire left skin...... NOT going to happen
2. Leave as is, use epoxy filler to fill in missing skin.
3. Add a large doubler under the entire NACA vent and recut the hole, still having to add some filler where the skin is missing.
4. Do #3, but also add small pieces in front of the doubler to bring flush to the skin.
5. ?????
Questions, Do I need to add the doubler? What should I fill it with?
I can't believe I did this... ARRRGGG.
Bill
Old 06-09-2011, 08:58 PM
Danny7 Danny7 is offline
have you read this thread?
http://www.vansairforce.com/communit...ight=naca+vent
nothing special here...
Old 06-09-2011, 08:59 PM
Hmmm, I wonder if it would work for a cabin air outlet?
Seriously.
Dave
Old 06-09-2011, 09:30 PM
LeeM_2000's Avatar
LeeM_2000 LeeM_2000 is offline
Sorry about your fubar. Here is the embed.
Old 06-09-2011, 09:55 PM
flion's Avatar
flion flion is offline
Actually, despite the advice I gave in the other thread, this time i would replace the skin. The strength of the design resides largely in the skin and making a patch and doubler to fill the opening would be much more extensive than in the other guy's situation. I know the thought of drilling off the whole skin is horrible but you are talking to the guy who drilled off and replaced his HS skins because of some cosmetic dents.
EAA Technical Counselor #5357
Old 06-09-2011, 11:51 PM
ao.frog ao.frog is offline
Default Give...
... Vans a call.... I'm sure they'll point you in the right direction...
Regards Alf Olav Frog / Norway
First RV-7 completed, (bought partly finished from a US-builder) 305 hrs per July 2014, SOLD
Second -7 had first flight Feb 25th 2014. 220 hrs pr July 2019. Life is good!
Old 06-10-2011, 02:17 PM
elippse elippse is offline
BTW, those aren't true NACA ducts; they are quasi-NACA ducts since they have somewhat the same shape but definitely not the true dimensions. And unless you have run some definitive comparitive tests between these and a true curved-divergent-submeged duct, don't tell me how well they work. Dang near anything will work, but not well. A much more compact and better-flowing duct would be the NACA parallel-wall-submerged duct. It flows better than a true "NACA" duct at high flow rates, which is really what you want, and it's much easier to make.
Old 06-10-2011, 08:30 PM
glenn654 glenn654 is offline
Try not to beat yourself up too much. Some days we just shouldn't be in the shop.
I did one much like that and it can be repaired w/o replacing the skin.
I used a solution much like your option 3.
I made a doubler backing plate then made a pattern of the necessary shape
to fill in hole in the skin allowing for the vent opening.
Then I drilled a few holes for riveting and dimpled for countersunk rivets to
attach the doubler to the outer fill in piece.
Then drill the necessary holes to attach the doubler/fill in to the skin, countersink. Also drill the holes to fit the scoop.
Rivet everything in place and mix up some micro to fill in the seam around your fill in piece.
Sand when cured and when painted only you will know what happened....
And I'm sure you'll never tell.
Glenn Wilkinson
_____________________________________________
RV-4 Sold
N654RV @ MLJ
RV-7 Coming Soon
N987RV Reserved
2015 Donation Gladly Paid
"Maintain Thy Airspeed, Lest the Earth Arise and Smite Thee"
Old 06-10-2011, 08:36 PM
apkp777's Avatar
apkp777 apkp777 is offline
#4. (blah, blah, blah (message to short with just #4)
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 06-15-2011, 07:05 PM
Thanks for the information, especially for the pointer to the post of someone else who had almost as bad of a mistake. If I did not have his fix as reference I'm not sure I would have come up with as good of a solution, or at least it would have taken a lot longer. 12 hrs of repair later here is my vent.
A full writeup of my repair at:
https://sites.google.com/a/fusion4.n...asterandrepair
Bill Thomasson
RV-10 - Flying - Phase II. 99.8% done... it's never really done!
http://sites.google.com/a/fusion4.net/rv10/
Suwanee, GA.
