Mike,
For my -8A I got one of the Bogi-bars from Aircraft Spruce. It was something like $60 but I was too lazy to make my own. Before I installed my wheel pants I was engaging the towbar over the hex-socket screws that serve as the forward fairing attach point. After installing the fairing I realized that I had only made the holes big enough for the hex wrench so the towbar wouldn't fit in them anymore. I was about to enlarge them when I realized that the holes for the axle bolt through the wheel are just exactly big enough to fit the towbar into, and it works just as well there.
The only word of caution on the Bogibar is that it engages with an overcenter spring action and if you're not bracing your arm against the lever, it will snap into place very quickly and with significant force. It would probably break the fiberglass on your wheelpant, or at least gouge the paint, if you weren't ready for it. Otherwise if you're aware of this and use caution it works fine...
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D flying 29.2 hours and grinning like an idiot
