Old 06-06-2011, 12:18 PM
Jerry Fischer's Avatar
Jerry Fischer Jerry Fischer is offline
Default Clamp to intake tubes
Any ideas on routing the alternator wiring harness from the alternatoe to the firewall? I was thinking of a standoff cushion clamping to the intake tubes as these are lower temperature on underside (away from cylinders) and away from exhaust pipes.
I appreciate any input. Thanks for looking
Jerry
Jerry Fischer KW4F
VAF# 1646
USS Randolph CVS-15 V-6 Div. AT2
RV7 N364SJ Miss Sandy sold
RV1 N1583 "Mockingbird 1" SOLD
EAA volunteer SNF
HBC volunteer/co-chairman OSH
Tech counselor
Old 06-06-2011, 12:21 PM
gasman gasman is offline
Pan bolts work just fine..............
Old 06-06-2011, 12:39 PM
shuttle's Avatar
shuttle shuttle is offline
Jerry,
My TMX-IO-360-M1B has a stainless steel propellor governor oil pipe under the right-hand cylinders. This pipe is cushion clamped to the pan bolts. I used more cushion clamps on this pipe as a stand-off for the alternator cable.
I used your suggested method of attaching to the intake tubes on the left-side to hold my fuel hose. This is the method in the Van's drawings. My starter cable goes down the left side too. I am am awaiting fitting of my mixture cable before deciding how best to clamp the starter cable. I'll need to keep the starter cable away from the fuel line.
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 06-06-2011, 12:40 PM
Default Pan /Bolts???
I guess I'm slow due to age or the heat or whatever, are you saying panbolts to hold the clamps to the intake tubes and the standoff clamps for the wire harness??
Jerry Fischer KW4F
VAF# 1646
EAA volunteer SNF
Tech counselor
Old 06-06-2011, 12:42 PM
Default OHHHHH
Those pan bolts!!! IADA
Jerry Fischer KW4F
VAF# 1646
EAA volunteer SNF
Tech counselor
Old 06-06-2011, 02:01 PM
oil pan bolts.......
Old 06-06-2011, 04:26 PM
Default Oil Pan Bolts
Right Arm (an old Navy expression)
Jerry Fischer KW4F
VAF# 1646
EAA volunteer SNF
Tech counselor
