06-05-2011, 08:27 PM
Engine Keeps Wanting To Die
I have a buddy with an RV6A with O320 carbed 160hp. For about the last year, every time he lands, after touchdown the engine keeps wanting to die. He has to pump the throttle to above 1200rpm to keep the motor running....not good on our 2200' grass strip. He runs 100LL and this happens with the engine hot or cold. Both hard surface and grass strips. The engine idles at 700rpm. Other than that, the engine runs great. Today though, he said he couldn't get the engine shut off with the mixture...had to cut ignition off to shut down engine??? Any ideas???
Jim Brown
RV6, Christen Eagle II(Sold)
ATP, CFII, A-IGI, A&P/IA
Carrollton, GA
Lyon?s Landing
06-05-2011, 09:08 PM
Idle mixture? Just a guess. -Jim
06-05-2011, 09:15 PM
Hmmmm
sounded like a plugged tank vent at first but the mixture thing doesn't jive.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
06-06-2011, 04:28 AM
Try landing with the electric (aux) fuel pump off and see if it still wants to die on touchdown. It sounds like the engine is getting too much fuel. I have had the same problem and it turned out to be a faulty engine driven fuel pump. It did not keep a steady pressure from the engine driven pump to the carb with the electric fuel pump on. Result was an overfilled carb killing the engine..
Mine ran fine with the elctric pump turned OFF but died with the pump ON which had me puzzled and dazzeled since one expects the opposite....
Do you have a fuel pressure gauge ?
Simon C. Paul
Maastricht Airport (EHBK/MST)
The Netherlands
RV-9
PH-SCP
"Building an aircraft is the male equivalent to giving birth, it only involves more blood and pain "
06-06-2011, 05:46 AM
Moderator/Tech Counselor
Sounds like the float level is too high, sinking float syndrome, or leaking float needle valve.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
06-06-2011, 05:48 AM
Thanks for the replies, guys. We've looked at his idle mixture and it idles at 700rpm. I suggested he lean the mixure on final to see if it helped, but yesterday it did the same thing. We'll try turning off the electric fuel pump on landing next. Thanks for the suggestions.
Jim Brown
Carrollton, GA
Lyon?s Landing
06-06-2011, 05:52 AM
Just a idle thought here on trying a landing with the electric pump off with his issues. Perhaps do it at altitude first in landing configuration/speed/descent etc just to make sure that the engine does not die at low altitude.
PS. Considering the runway length, do it over an airport with a longer runway in case a deadstick landing is required. Know the in air restart method before trying it.
06-06-2011, 06:37 AM
Copy that.
Jim Brown
Carrollton, GA
Lyon?s Landing
06-06-2011, 07:05 AM
I had this happen with my carbed O-320 recently... But it was before takeoff. Wanted to quit at idle, and bounced around from 1000-1400 when I tried to set it at 1200. Oddly enough, turning the fuel pump on seemed to clear it enough to fly the 10 minutes back to my home airport where I pulled the lower cowl and plugs... Where I found nice big lumps of lead between the ceramic and the shell on 3/4 plugs.
After cleaning the lead out with a dental pick, the problem has gone away. I'll be checking those at each oil change now instead of just at annual.
Rob Prior
06-06-2011, 07:49 AM
If it has a hand primer system on it I would check and make sure its locked closed. If it has elec primer I'd check for broken lines or drawing fuel. Just an idea if everything else fails.
Shine'r
