Old 06-04-2011, 08:59 PM
sglynn's Avatar
sglynn sglynn is offline
Default Coolie Hat Wiring Schematic
How do you wire the Coolie hat for aileron and elevator trim? Coolie hat has 5 posts and when you move the switch it connects one of the four posts to the common post. So I can make the common ground and put the Ray Allen white wires on the other four, but how does power get connected? The servos have 3 other wires, but Ray Allen shows them going to a position meter and doesn't show if there is a power wire.
thanks for your help
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 06-04-2011, 09:16 PM
airtractor8 airtractor8 is offline
All the instructions for the 4 way switch are here in diagram 2 http://www.rayallencompany.com/RACme...ctionsREL2.pdf
The switch must be used in conjunction with Rel-2 relay deck. A speed controller is also a good idea. http://www.rayallencompany.com/products/switches.html
Good luck
Old 06-05-2011, 05:34 PM
sglynn's Avatar
Default wiring the coolie hat
Thanks, I see now. I need to add the Rel-2 Relay Deck, one per trim servo. Got it. I've order 2 Rel-2 Decks from Aircraft Spruce. And I see these Relay Decks are needed because the coolie hat is single pole rather than double.
Thanks much.
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
