Old 06-03-2011, 01:44 PM
PH-SCP PH-SCP is offline
Default Oil analysis kit
Hello RV'tors,
I am getting close to my 50 hours check on my RV-9 and I would like to do an oil analysis to verify how my O-320 is doing.
Aircraft Spruce offer several Oil Analysis Kits.
Which one is dependable ?
Cheers
Simon C. Paul
Maastricht Airport (EHBK/MST)
The Netherlands
RV-9
PH-SCP
"Building an aircraft is the male equivalent to giving birth, it only involves more blood and pain "
Old 06-03-2011, 04:42 PM
turbo's Avatar
turbo turbo is offline
i have been using spectrum labs for a long time. call for some kits and see a nice report from them. http://www.spectrumlaboratoriesinc.c....aspx?pageid=1
TURBO YES =VAF= Payed Jan2019
Ed D'Arcy
addicted pickle ball player
Old 06-03-2011, 05:13 PM
OneCharlieKilo's Avatar
OneCharlieKilo OneCharlieKilo is offline
Default Blackstone Labs
I've used Blackstone Labs for a number of years and am happy with their service. You can order the kits (prepaid, or just order free kits and pay when you send in sample) off their web site:
http://www.blackstone-labs.com/
You can pull up your results report history on-line if desired and they'll email you the reports as well.
If you want to see example of what you get from Blackstone (I expect other labs do something similar), the report from my December 2010 oil change, including the previous results for trends, is posted on my RV web site at:
http://rv6aproject.ckhand.com/PhaseI...ilAnalysis.htm
Chris
RV-6A, N731CK, 300+ hrs
Poulsbo, WA
Last edited by OneCharlieKilo : 06-04-2011 at 12:16 AM. Reason: added link to example report
Old 06-03-2011, 05:44 PM
flyingriki's Avatar
flyingriki flyingriki is offline
Default Blackstone
Ditto OneCharlieKilo...! They email results and will even call you if something worries them. Great guys.
Old 06-03-2011, 08:49 PM
Greg Arehart's Avatar
Probably the key is to use one lab rather than getting analyses from multiple labs (my two cents as a user of chemical labs on a regular basis, though not necessarily for oil). What you want to establish is a trend, and each lab will have some slightly different procedures, but typically they are internally consistent, which makes for better long-term comparisons of your data.
greg
Greg Arehart
N 7965A
Old 06-04-2011, 06:26 AM
Default Thanks
Thanks guys... I mailed Blackstone Labs for a kit and will work towards a lasting relationship with them to analyse my oil.
Simon C. Paul
The Netherlands
RV-9
PH-SCP
