Originally Posted by rocketbob
Larry if I understand what you are wanting to do, its not going to work because the diodes will prevent the batteries from charging.
How about this set of connections.....
Aim: Auxillary Battery to provide alternate power source for Avionics. Does not aid engine starting.
1) Main battery to Contactor to Main Buss.
2) Main Buss to schottky diode to on-off switch/relay to Avionics/Ebus. (Avionics Master Switch)
3) Auxillary Battery to schottky diode to switch/relay to Avionics/Ebus. (Avionics Aux Battery Switch)
4) Main Buss to schottky diode to 3 ohm resistor to Auxillary Battery.
Aux battery is charged via route 4) with resistor managing/limiting current inflow.
Routes 2) & 3) allow either or both batteries to feed the Avionics/Ebus.
Appropriate CBs/fuses applied in appropriate locations.
Alternator feed comes in at the usual place.
Does not quite matches Larry's original spec but is there or there abouts.
