Old 06-02-2011, 11:59 PM
newimaging's Avatar
newimaging newimaging is offline
Default Identifying Washers
What is the difference, or how do you identify a AN960-10 Washer vs. AN960-10L Washer?
Didn`t find anything in the Standart Aircraft Handbook.
Christian Stoehr
Winnetka, CA 91306
Looking for a Fuselage
http://www.stoehrfamily.com/airplane
Old 06-03-2011, 12:01 AM
Sig600 Sig600 is offline
Short answer, the 10L are thin. Best tool I've found for identifying certain hardware (since Van's just assumes you know what every bit is in a bag of 100 parts) is Google searching it in "images" on my iPhone. 95% of the time a picture will come up.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 06-03-2011, 12:13 AM
newimaging's Avatar
Thanks, that was my guess "L" for "Light" but I didn`t want to assume. The google tip is great.
Christian Stoehr
Winnetka, CA 91306
Old 06-03-2011, 03:23 AM
jrs14855 jrs14855 is offline
Default washers
-10 approximately .063 thich, 10L approx .032. If you don't have them get a set of inexpensive dial calipers to measure just about anything except engine parts.
Old 06-03-2011, 06:47 AM
Capflyer's Avatar
Capflyer Capflyer is offline
When I first started building it was confusing which was what on the different sizes all in the same bags. Once I was able to ID the washers I traced them on a sheet of paper for reference as the project progressed....kinda like they do at Aviation Depot for the cashiers. After a while I was able to ID them all by sight and the cheat sheet disappeared.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 06-03-2011, 07:17 AM
Bob'sRV6A Bob'sRV6A is offline
Default The search window in Aircraft Spruce is handy.
I recently had a similar question and just entered the AN number. A picture popped right up.
Old 06-03-2011, 07:22 AM
randyintejas's Avatar
randyintejas randyintejas is offline
I do find myself doing this very thing, often!
RV 7
391RK Reserved
IO360 9:5:1 AFP
Slow Build
Last 90%
Tyler, Texas
Old 06-03-2011, 08:11 PM
Joe Parish Joe Parish is offline
Section 5 of the paper work that came with the empennage on page 5-17 is a chart that gives the washer part#, inside & outside diameters and the thickness of the washer. I use my 6" caliper to measure them if I am unsure.
Joe
RV-9A N525XC
Superior IO-320
Dynon HDX
Flying as of 5-4-18
