Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 06-02-2011, 05:27 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default Hartzell HC-C2YK-1B/7666A-2 ??
I am considering buying this prop from a local friend. He had it overhauled in 2002 and then subsequently bought a new prop instead. So it is 0 time since OH. I looked at it today and looks great. I was unsure though, (and so is he) as to whether this prop has the recurring 100 hr ECI AD. The paperwork he gave the prop shop says HC-C2YK-1A/7666A-2, but when it came back the new paper work (and engraved on hub) is HC-C2YK-HC-C2YK-1B/7666A-2/7666A-2. Would someone here know? Just checking, I will also call hartzell or a prop shop tomorrow.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 06-02-2011, 05:56 PM
Radomir's Avatar
Radomir Radomir is offline
you need hub's serial.. it typically (but not necessarily) starts with "CH..." and oh, the A you pointed out is not the A that matters..
Radomir
RV-7A sold
Old 06-02-2011, 06:13 PM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
Ditto about the hub serial number.
Also I'd give serious thought to the fact its been sitting around for 11 (?) years; technically its overdue for calendar overhaul.
Alan Carroll
RV-8 N12AC
Old 06-02-2011, 06:17 PM
miyu1975's Avatar
I have the FAA form 8130-3 (took a pic) box 11 is Serial/Batch Number CA26...is that what I am looking for?
Ryan Allen, CFII
E-170/175
Old 06-02-2011, 06:22 PM
Radomir's Avatar
It should be, but I'd check by looking at the prop itself.. it's engraved on the hub... wouldn't trust a piece of paper that may or may not be correct...
As Alan pointed out, if it sat that long I'd have a prop shop re-seal it before flying it ($500-$600).... and would include this number into the overall "out of pocket cost" so you don't end up overpaying.
Radomir
RV-7A sold
