Old 06-02-2011, 08:18 AM
brian's Avatar
brian brian is offline
Default spring in Airspeed Indicator pitot inlet?
As part of installing an EFIS into my RV-6A (and keeping original ASI), I am replacing all the pitot & static lines behind the panel.
I'm using Tygon tubing for it, and the Tygon didn't fit well over the AN fitting on the back of the ASI, so I unscrewed it to replace it with a poly barbed fitting. I was surprised to find a spring inside the fitting.
I don't see anything inside the ASI inlet that the spring would be operating against.
Does anyone know what this might be for? Is it required for something, or can I just replace it with my poly barbed fitting & get on with the install?
Fitting & spring:
ASI inlet:
thanks for any help,
brian
Brian Meyette, Cornish, NH
1995 RV-6A - N16RK (Ralph Koger) SOLD
RV-7A - incomplete, supercharged Subaru STi - N432MM - SOLD
2001 Quad City Challenger II LW - N28RT SOLD
www.meyette.us/RV-7Ahome.htm
Old 06-02-2011, 11:08 AM
gasman gasman is offline
That fitting came out of your airspeed indicator?????? I would bet that spring is not needed. If the asi is the normal Vans unit, clean up the threads and inlet area and install your new nylon fitting and then test the system when done.
Old 06-02-2011, 11:42 AM
brian's Avatar
Default yep
Yes, it did come out of the airspeed indicator pitot inlet. Not very pretty, is it? I especially like all the gunky thread sealer all over the end of the spring. Looks like Permatex.
Old 06-02-2011, 11:58 AM
rocketbob's Avatar
Did you try pulling the tube out shown in the second picture? Maybe the spring is what is making that part seal.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 06-02-2011, 01:42 PM
brian's Avatar
The little tube inside the ASI pitot port appears to be either a fixed part of the ASI or it's well glued in - no movement at all. Do others' ASIs have this little tube in the port?
Old 06-02-2011, 03:06 PM
mikeflys8's Avatar
mikeflys8 mikeflys8 is offline
I would suggest that it may be a "tension" spring too keep the fitting tight???
Old 06-02-2011, 06:14 PM
No. None of the five that I have owned...........
