Old 06-01-2011, 07:29 PM
tx_jayhawk tx_jayhawk is offline
Default Thread Sealant or not on Oil Temp Probe?
THis is the 5/8 - 18 thread probe. It has the copper crush washer. I've snugged it down as tight as I dare, and I still seem to be getting a little leakage from under the probe.
It is "standard" (not pipe) threads, so I do not think one should technically be installing thread sealant on it. That said...I still seem to have a problem with a very small leak.
What have others done? If you used sealant, what type?
Scott
Old 06-01-2011, 07:47 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Crush Washer Only
I installed the crush washer only and have experienced no leaks.
Make certain that you have the proper size crush washer and that you have torqued it to the correct spec.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 06-01-2011, 08:05 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Scott,
Also, make sure the probe is not bottoming out before compressing the crush washer. Not likely, but possible. Try a new crush washer, shouldn't need any sealant.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 06-02-2011, 06:26 AM
mahlon_r mahlon_r is offline
Make sure the housing doesn't have a small crack where the probe screws in. Have seen many cracked over the years.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 06-02-2011, 06:49 AM
apkp777's Avatar
apkp777 apkp777 is offline
I have seen where the crush washer was installed backwards (opening facing aft). Should be facing toward the housing.
Tony Phillips
N524AP, RV 9 (tail wheel)
