Old 06-01-2011, 03:19 PM
FresnoR's Avatar
FresnoR FresnoR is offline
Default Material Properties of Steps
Does anyone know the metal properties of the steps?
I took mine to a welder to have a gusset welded onto the bottom of it prior to installation, and the welder thought that it might be a special type of steel in which he would want to match.
thanks!
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 06-01-2011, 03:25 PM
guccidude1 guccidude1 is offline
I just finished having gussets wielded on my -9A steps. I used 4130 .062" steel for the gussets. It welded fine and is very strong. Dan
Old 06-01-2011, 04:02 PM
Bob'sRV6A Bob'sRV6A is offline
Default any photos?
I'm thinking of doing some type of reinforcing of my steps before initial installation. Photos from previous threads look good. Did you do yours the same way?
Old 06-01-2011, 04:06 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Your steps are 4130, we use Esab-65 rod to weld them, I believe it’s 70-S2, you could also use 4130 rod, not quite as nice to work with but it’s ok.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 06-02-2011, 08:24 AM
bkthomps bkthomps is offline
Originally Posted by Russ McCutcheon View Post
Your steps are 4130, we use Esab-65 rod to weld them, I believe it?s 70-S2, you could also use 4130 rod, not quite as nice to work with but it?s ok.
well, you heard it from the man yourself!
Old 06-02-2011, 11:31 AM
FresnoR's Avatar
Thanks all,
That's what I needed to know!
Rick from Fresno
RV-7A
Old 06-02-2011, 07:32 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
Rick,
4130 is also known as Chrome-moly, maybe your welder is familiar with that. Steps are not exactly a critical structural part and you can weld other types of steel to it.
Russ,
Since you are in the business, do you recommend welding with 4130 rod on this type of weldment, without heat treating after? Never welded with this rod but every text I've ever read recommended heat treating after welding.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
