Old 06-01-2011, 01:30 PM
ron sterba ron sterba is offline
Smile 9A Vert & Hori stab Fairing. Why After_market
I'am building a 9A. I usually go to school on every aspect of building. Always asking questions until I get to the end of my brain flow chart. I noticed that FAiring etc advertises on Vans airforce for fairings. Can somebody tell me the benifits of the FAIRINGS-ETC.com over the Van's factory ones. Why do you like them? Appearance? Fit? Workable? or Less work to finish?
Ron in Oregon
Old 06-01-2011, 02:38 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Could it be that you don't have to hack them apart and re-glass to fit? I have had to do that on 2 of Van's tail fairings...Just sayin'....
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 06-01-2011, 02:44 PM
Jamie's Avatar
Jamie Jamie is offline
I honestly think the fairings on the 6's were worse. On my -7A the fairing fit pretty darn good out of of the box.
Some (quite aged) build pics.
http://rv.jpainter.org/?view=entry&date=2007-07-14
Old 06-01-2011, 02:45 PM
Paul K Paul K is offline
Default tail fairings
Hmmmm, My tail faring from Van's fit great! Very little adjusting needed. No cutting apart, no glassing anything new, just a little filler to make it match the skins really tight. I can't understand what you guys are going through.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 06-01-2011, 02:52 PM
Daver Daver is offline
Default emp fairing good
no issues here with Van's fairings.
the problem is I just don't like fiberglass
but everything fit pretty good.
Dave
-9A flying
Old 06-01-2011, 05:15 PM
My experience is different. I have two (thanks Mark) and none fits as desired. Now I am in a stubbornness competition will see who wins - fairing or I .
Old 06-01-2011, 05:48 PM
DanH's Avatar
DanH DanH is offline
Shocking as it may be, you're allowed to make your own fairings....
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-01-2011, 05:55 PM
flion's Avatar
flion flion is offline
Some people had a lot of trouble. Some just offset their fin to try to 'pre-trim' the aircraft. Others, like me, built it to the plans and had the fairing fit right out of the box. On the other hand, I am still swearing at the gear intersection fairings and wish the latest vendor had started up several years ago. Nothing wrong with aftermarket parts to tweak the fit, in my opinion.
EAA Technical Counselor #5357
Old 06-01-2011, 07:16 PM
Jamie's Avatar
Absolutely! I have the fairings-etc intersection fairings and they are awesome.
Old 06-01-2011, 09:10 PM
Hi Jamie. You said intersection fairings. Are these on the wing root or gear. Did you use Vans for one and Fairing etc for the wing and gear? Why did you like Fairings etc?
Ron in Oregon
