Having just recently done this, I think it is the most "catch-22" of any task in the build. The baffle kits fit the engine, not the plane. You have to make it fit the plane (meaning cowl). The cowl for a tandem plane has a different curvature in the oil cooler corner than a side by side. You have been supplied a generalized "vanilla" baffle kit that has enough aluminum to fit all cowl circumstances.
SO, you have to cobble the baffles together well enough to be able to trim them to fit the upper cowl, THEN decide how high you want the oil filter and then start hacking the hole to fit the doubler and cooler. Leave that "box" piece above the cooler off the baffle assy for this first cowl fitting. Bring it into play before cutting the big hole, though.
Viola'. Done.....
Good luck. There are a bazzilion parts on the baffles. I have 17 log entries on baffles and I ain't done yet.
Bill Pendergrass
ME/AE '82
