Old 05-31-2011, 08:22 PM
Default wing tip installation
I'm following some instructions for installing the wingtips on the 7A -- which I think I found around here somewhere. It says to use "bead foam" to make and impression of the wing tip rib. I'm not familiar with "bead foam." What is it?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-31-2011, 08:54 PM
aerhed aerhed is offline
Expanded polystyrene, AKA "cooler foam"
Actual repeat offender.
Old 05-31-2011, 10:42 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Simple stuff
Hey Bob,
You can get it at Home Desperate or (S)Lowes. Press it against the tip skins to get an impression then cut out.
Work the template until it fits. When done put a couple of chordwise runs of duct tape on it to stiffen things.
Also on the opening page, look under "articles," on the left side, for my two part series on installing the wing tips. Should help take some of the work out of it.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 06-01-2011, 06:41 AM
Aha! It's your directions that I'm working off. Figures. I never go wrong following your glassing advice.
Bob Collins
St. Paul, MN.
Old 06-02-2011, 01:36 AM
Bob Ellis's Avatar
Bob Ellis Bob Ellis is offline
Bob
Before making a foam rib take a look at my log (Wing Tips 2 has my solution). I used a Sat Nav holder with a suction cup and used that to pull the wing tip up as I drilled.
Regards
Bob Ellis
www.rv-8.co.uk
90% done 90% to go
Old 06-02-2011, 05:27 AM
RVRC's Avatar
RVRC RVRC is offline
Thumbs up I too am using those instructions
Bob, i am using Darwin's instructions as well. Got the first tip drilled yesterday. Great stuff. Thanks, Darwin! The white foam is what was used as packing in some of the kits from Van's. I saved some just knowing I would need it. One thing to look out for, I made two of the alignement pieces that go over the trailing edge as per instructions, but when clamping, didn't notice that it move the aileron not the tip to line up. I now have 1/4" low tip on my wife's side of the plane. everything else has been great. Even made the two Drimle tools. Bought from some already tapered grinding stone from Lowe's Aviation Dept and modified them.
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
Old 06-02-2011, 01:07 PM
You know when I use that aileron bellcrank, that's about how much play there is in the aileron for me. After 10 years of building, while my attention to detail has now reached the OCD stage, my concern about 1/4" seems to be ebbing.
Bob Collins
St. Paul, MN.
