Old 05-30-2011, 03:19 PM
PH-SCP PH-SCP is offline
Default Carburetor for O-320-D2J
Hi Guys,
Today I developed problems with the carburetor of my O-320-D2J.
At full power, with the Aux Fuel Pump switched on, the engine quit on the runway during take-off roll.
I have a Marvel-Schebler NA-4SRA (P/N 10-5135) but cannot seem to find a replacement with Aircraft Spruce.
Does anyone know which carbs are approved for a O-320-D2J ??
Thanks !
Simon C. Paul
Maastricht Airport (EHBK/MST)
The Netherlands
RV-9
PH-SCP
"Building an aircraft is the male equivalent to giving birth, it only involves more blood and pain "
Old 05-30-2011, 03:42 PM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default MA-4SPA
Hi Simon,
I guess you had trouble reading the carb plate.
The model is MA-4SPA and the part number is 10-5135.
You might want to search Aero-In-Stock for this p/n, you'll find 2 matches.
You can find the carb to engine X-ref here
Cheers
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Last edited by FlyingArcher : 05-30-2011 at 04:00 PM. Reason: Additional link to x-ref
Old 05-31-2011, 02:20 AM
Originally Posted by FlyingArcher View Post
Hi Simon,
Cheers
Hi Daniel,
Thanks for that. You are absolutely right. I was frustrated and tired when reading that model number and the result was a bad result. The P/N pointed to the correct model number...
Time to shop around for a new carb..
Best regards
Simon C. Paul
The Netherlands
RV-9
PH-SCP
