You have a few options. Don's method is the easiest. If you have access to CAD software (a good, free program is
DraftSight) you can just draw a 6 degree line and print it out. Or, you can do it the old fashioned way and do the math and draw yourself a triangle. The tangent of an angle is tan(θ) = Opposite / Adjacent. You know your angle is 6 degrees and assume that the adjacent leg of your triangle is 6" long. Doing the math means the opposite leg of the triangle is .630" or a little bit more than 5/8". In other words, draw a 6" line, then draw a 5/8" line perpendicular to that line. Connect the two lines to make a triangle and you have a 6 degree line. I hope that's clear.
