Originally Posted by Jekyll
Bob:
Sorry, I don't know what you mean. I installed my AFP setup earlier this month and I didn't see any fit conflict. I bought my pump system last month. Bend lines per the drawings and then just massage them a bit to fit. I agree that it sure looks like a challenge but, it is doable. I only had to redo 1 line, the others went in on the first try.
Sit back and have a beer while you noodle it over.
Jekyll
The problem with the AFP boost pump conflict was reported by Dan Checkoway on Jan 16, 2003. For further illustration on his website you may go here.
http://www.rvproject.com/20030116.html
However the problem was reported in the archives well before this date. I bought my AFP boost pump kit from Vans in December 2005 and the problem still existed then. I had several friends who bought the pump from Vans between Jan 2003 and Dec 2005 and all had the same problem. I think it is therefore obvious and clear that vans shipped the wrong configuration for a number of years despite the fact that many people contacted them asking how to fix the problem.
Perhaps they have now gotten around to instructing AFP to supply the pump with the fuel tube as per the Vans drawings.
I don't need to noodle over the thing anymore...but thanks for your suggestion. I can identify a physical conflict when I see one....it's when two objects both want to occupy the same space at the same time.
