05-23-2011, 12:49 PM
Some computer usage tips.
My son is a graphic arts graduate and gives me tidbits from time to time.
I wondered how I could get degrees Fahrenheit shown as the little circle, like this 90?. Also the little thingy on some 'e's...like this... "pat?." And then the approx. sign... ?, like this one. Turns out that we have a "Character map" feature that has all these and many more. It's accessed by:
Start/programs/accessories/system tools/character map. You then select the "thingy" you want and copy it. When you reach the point in your post where you want that said 'thingy', you simply paste. voila!!
Comp 101,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
05-23-2011, 12:54 PM
Comp 101,
degrees?˚? for a mac you can go to edit file, drop down to "special characters", then explore all sorts of stuff
nothing special here...
05-23-2011, 01:00 PM
unqualified unfluencer
Easier way (on a PC)
Hold down the ALT key and type in 0176 on the numeric keypad. When you release the Alt key a ? will appear on the screen where your cursor was.
If you are looking for the ? symbol, it's 0177.
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Part time: Supporting Crew Member CAE Embraer Phenom 300 (E55P) @ KDFW.
- Occasionally: Contract pilot (resume).
05-23-2011, 01:03 PM
Originally Posted by DeltaRomeo
Hold down the ALT key and type in 0176 on the numeric keypad. When you release the Alt key a ? will appear on the screen.
In the bottom right of the character map program, it will give you the code to do what DR is showing you. It will save you some time if you know the ASCII code.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
05-23-2011, 05:04 PM
ALT 248
Or,
Save a keystroke and type Alt-248...?
Paige
05-24-2011, 02:29 AM
Or save yet another keystroke with Unix: compose-oo → °, compose-+- → ±, ...
Hendrik
Club-Libelle: flying
RV-8: on hold (new job  , new home  , no workshop (yet)  )
05-24-2011, 03:48 AM
I knew that!
I am a sad geek.
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
05-24-2011, 04:49 AM
Not on my computer.
I tried your method, DR...no joy...doesn't work and I have Windows XP, Media Center edition.
Thanks anyway,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
05-24-2011, 06:00 AM
on a mac......alt k.
Does not get shorter than that.
05-24-2011, 08:21 AM
Thanks anyway,
Pierre - You must use the numeric keyboard on the right side of the keyboard, not the numbers on the top of the keyboard. On a laptop you must enable your numeric keyboard (normally the letters m, j, k, l, u, i, o, 7, 8, 9) by enabling your NumLk function (on my laptop this is done by holding down the Fn key and pressing the NumLk key once, but this varies from laptop to laptop.)
If you do this be sure to toggle your NumLk function back off by using the same keystrokes as you used to turn it on or you're going to find yourself typing some pretty strange things!
Done properly this will work on all Windows based computers as far as I know and it's a handy shortcut. As you said though the Charmap program is very useful if you can't get this to work, you want to use unusual symbols, or you simply want to look the codes up for common symbols like degrees, trademark, or copyright.
Best,
Steve Jarrell
Building RV-14A QB "Freedom"
N614US (June 14 - Flag Day)
Dues Paid - Gladly!
Reason: Added note
