Old 05-22-2011, 06:20 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Accessory Oil fitting swap
I am really hoping someone can tell me this works, as I want to hang the engine today, just must do it today. OK I guess not but that was the goal. You can see the shot of the plans that has the AN823 45 elbow at the lower port that is between the two mags and this goes to the cooler, the upper port gets a straight nipple. Well I realized that I need a 45 for the upper one because coming straight out will not work with the 90 oil filter adapter.
I want to use the straight nipple for the lower and the 45 for the upper. I don't know exactly what level the lower port on the oil cooler is so I can't make a call as to if this will work. If you look at the picture you can see the line with the 45 fitting at the back of the case, coming straight out and then looping to where I think the lower cooler fitting sit might work. Of course it is easier to make this change now with the engine off.
I am hoping someone can tell me hey used the straight nipple on the lower port of the accessory case. My prop cable bracket sits on the face of the governor and looks like the oil line will stay above it. If I can get a "yes this worked" for you answer soon I might actually get the engine on this weekend, or at least in a day or two.
Yellow highlight line points to the two fittings I want to swap.
This is taken looking level at the lower oil line port, Oil line is attached to the 45 nipple. Looks like it will not conflict!
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 05-22-2011, 09:55 PM
Default mike--
looks ok from here. Might change the hose lengths alittle.
Tom
Ridgeland, SC
Old 05-22-2011, 11:46 PM
Lars Lars is offline
I wound up using straight fittings at both inlet and outlet. Because of where my cooler wound up on the baffling, the FWF kit hoses didn't work out, so I had new ones made, including a 45 on the engine end of the feed hose (actually, both of them in my case, since it made routing easier). The nice thing about having the 45 on the hose is it's easier fine-tune the position. The bad thing is you need to buy a hose to get it.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 05-23-2011, 03:08 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I was just looking at my -8 to refresh my memory to do the -3, and I used the 45 on the upper, straight on the lower, and stock Van's hoses to the baffle-locad oil cooler. Has worked well for 1300 hours.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-23-2011, 09:06 AM
RVG8tor's Avatar
Default Sweet
I was almost ready to commit to the swap when I read the last few posts, it is nice to know this will work. I was going to do it thinking worse case I would have a hose made with the sweep 45 to attach to the straight nipple.
The swap happens today and by night fall my engine should be on the plane, Yee Ha!
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 05-23-2011, 11:00 AM
Mike, for what it's worth, I installed those fittings with the engine on the airplane. Mine is a 7, but I doubt the 8 is much different. I waited till the cooler was on the baffling, then installed the fittings hand tight and started messing with hose routing, in part because that's a topic about which I tend to get a bit (ok, a lot) OCD. Of course in the end it cost me a bunch of money because I bought new hoses, but even if I hadn't, it still made figuring out the optimal routing much easier.
Lars Pedersen
Davis, CA
