Old 05-22-2011, 10:37 AM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Default fabing my Plenum
Thought I would share the beginning of my plenum building..Last night I cleaned and waxed the mold (made from upper interior cowl) and layed 4 layers of S glass. I just got finished pulled the dried epoxy/glass and I am pretty happy with the initial results. It will need a little modifying, but all in all, very good so far....more to come...
the Mold.
While pulling out of the mold...it released very easily and I only cut myself a few times on the edges
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 05-22-2011, 10:40 AM
N941WR's Avatar
N941WR N941WR is offline
Looks great!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-23-2011, 01:38 PM
miyu1975's Avatar
thanks Bill..
I little more progress here. Cleaned up the edges and fitted it to the baffle...mostly.. Still some work to do on the left side rear, there is a gap and I have not decided how I am going to handle this yet. Also, I need to rework the inlets and widen them about an inch.. Haven't decided the best plan of action there either yet.
Left side rear gap.
I am thinking possibly to cut on the line here and move the outer piece where I need it and then lay glass over the gap.. ??
Ryan Allen, CFII
E-170/175
Old 05-23-2011, 01:51 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Ryan,
I'm very interested in following your methods and progress on this project. Please keep the details coming! Do you have a website or more pics somewhere online?
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 05-23-2011, 02:09 PM
scsmith scsmith is offline
Default just scarf the edges and lay on more glass
Your idea for the inlet widening is fine. Just grind the edges down to a thin edge, creating a tapered lap joint with the new glass.
Same thing for the gap in the back. You can tape a piece of cereal-box cardboard inside to form the shape a little bit, cover it with packing tape, and build up glass over it to extend the edge of the plenum out to where you need it. Again, just grind a scarf angle on the original glass to bond to.
The tricky part is going to be making the rubber boots to seal the plenum to the cowl intakes. Dan Horton has made some interesting reinforced rubber parts, you might check out his postings
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 05-24-2011, 03:26 PM
Pilottonny Pilottonny is offline
Question Benefit??
Hello,
Can anybody explain to me what the benefit of this is?? To me it looks a lot more work, more weight and less access to the top of the engine than the standard setup with rubber baffle seals against the inside of the cowling.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 05-24-2011, 03:56 PM
DanH's Avatar
DanH DanH is offline
The elimination of leakage, which has a host of benefits.
All true......there's no free lunch.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-24-2011, 04:08 PM
jdeas's Avatar
jdeas jdeas is offline
Default Very cool
Love using the top as the mold! I am one step behind and now rethinking the project to mold my top the same way.
Great work!
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 05-24-2011, 04:23 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default A further question
I think I understand the purpose. I have a SJ plenum under my SJ cowl. However, if I understand both the principles and the design of the SJ version, there is more to it than just reducing leakage.
As I understand it, as the air enters the volume above the cylinders, it is expanded because of the difference in intake area versus volume, taking into account speed. The speed is thus reduced. As I understand that, reducing the speed increases the pressure. The increased pressure is supposed to aid in the transfer of heat from the aluminum to the air. And so on.
In addition, the SJ version is gradually greater in volume toward the rear, an apparent technique for managing cooling rates of the individual cylinders. On mine, it seems to work quite well.
So my question is whether or to what degree that whole subject was applied to this design. To my unpracticed eye and taking the description of the use of the cowl and the mold, it was not. Lost opportunity?
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 05-24-2011, 04:30 PM
... also locks all baffles preventing cracks in oil cooler corner by stiffening it
Looking good Ryan just watch that gap between the cowling and plenum by the prop.
