Old 05-21-2011, 10:02 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Gasket overhang
I am getting close to hanging the engine and have been doing some reading. I also pulled out the mount (Lords) to see how things fit and are arranged. When I put the mount up to the lower end I realized that there is some gasket that hangs out from the Oil sump. The mount will pull up into place but this curls the part of the gasket sticking down some.
Would letting it curl down be better than taking a razor and cutting this off? I know this must seem like a dumb question but the gasket seems to have some type of plasticy coating, my thought is if I cut this and there is some inner material that would absorb fuel and oil, this might cause the gasket to fail. Of course curled over it might do the same overtime. I am not sure why the gasket does not fit perfectly the contour of the sump but it doesn't.
The engine is a TMX IO-360 with a vertical induction, I think the sump is the same as on an O-360. Hopefully one of you find builder has run into this before and can provide som advice.
Here is a picture.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 05-21-2011, 03:50 PM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Me thinks a sharp razor should do a good job lopping it off. Go for it.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
Old 05-21-2011, 07:18 PM
jrs14855 jrs14855 is offline
Default gasket
My Superior sump gasket is standard paper gasket material. Cut away.
Old 05-21-2011, 07:43 PM
flion's Avatar
flion flion is offline
Gasket outside the mating surfaces has no function. It really doesn't matter if you trim it or not so do as you prefer. If it actually interferes, remove it.
EAA Technical Counselor #5357
Old 05-21-2011, 07:48 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Take it off
As mentioned above its not used and useless. I'd take it off. There is enough safety wire and short zip tie tails to make you loose a pint every now and then. I'd hate to reach in and get a paper cut from that too.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-21-2011, 07:58 PM
Mel's Avatar
Mel Mel is offline
Default A word of caution!
Make sure you use a VERY sharp razor or knife.
A less than sharp blade can actually "tear" the gasket from between the surfaces.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-22-2011, 08:54 AM
RVG8tor's Avatar
Default Off it comes
Thanks gang for all the replies.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
