Old 05-19-2011, 06:45 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Tip: Crankcase Breather Hose
When I was doing an oil change a week or so ago, I discovered that my standard-issue breather hose elbow (from the crankcase fitting to the aluminum tube that runs down the firewall had finally swollen and gotten unacceptably gooey. I tried AE6000 hose (had some sitting here for the RV-3 inverted oil system), but it wouldn?t bend tight enough without kinking. Tom Swearengen from TSFlightlines.com dropped me a note that he might have a solution ? ?? steel-braided hose with a convoluted liner to prevent it from collapsing in a tight turn. I figured that it was that, or go back with another radiator hose that would get gooey again, so we gave it a try. It only took about 9 inches of hose, and I covered the ends with some giant, industrial-strength, adhesive-lined heatshrink, just to dress them a little (and prevent loose, raying stainless wires) ? and it worked great! I don?t know the hose part number, but it I?m pretty happy with it.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-19-2011, 07:04 PM
Talking paul--
post a pic of the other side so I can see your tube!! I have a few ideas on these, depending on space.
Tom
Paul
Ridgeland, SC
Old 05-19-2011, 07:16 PM
Greg Arehart's Avatar
Tom,
Let me know what you come up with. I'm looking for something better than the very stiff hose that I have.
greg
Greg Arehart
N 7965A
Old 05-19-2011, 07:37 PM
Default greg-
I actually crimp this hose to fittings, but I'm going to devise something that you can attach in the field. I can secure it with stainless bands, like firesleeve bands, and it looks great, just hard to do in the field. The other problem is the NPT fittings in the accessory case. In order to make a nice looking "crimped" assembly, you really need a male NPT swivel; but then you can get alittle bypass leakage from the internal o'ring. Using a AN816-12D would be ok, except not all guys are using the same stuff, and you may not be able to tighten a AN nut on the adapter. So, another custom situation.
Hose clamps work fine for most situations, if like Paul did, you wrap the ends so the stainless braid doesnet ravel.
This hose is very flexible---can be used for alot of applications, and unlike smoothbore teflon, convoluted it true bore sized, so standard hydraulic fitting stems work well.
I'll work on this a bit.
Tom
Ridgeland, SC
Old 05-20-2011, 06:57 AM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
Default Cold weather flight
In canada we require to punch a hole in the top of that hose just incase the breather hose exit ever froze up. It has happened to many and blows out the front seal. I am sure you know what happens after that. Everyone seams to fly in cold weather some times no matter where they live. Not a bad practice for all aircraft.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
Old 05-20-2011, 07:11 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Same here
In the US, we cut a notch in the tube near the exit for the same reason, but we make sure it is in the warm area of the flow. We call 'em whistle slots.
Carry on!
Mark
PS std hose can be used, but you gotta put a spring in the hose to keep it from collapsing. This particular installation looks very sanitary, BTW.
Old 05-20-2011, 10:07 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
This is probably just a optical delusion, but it sure looks like the new stainless hose is either touching, or close enough to touch the motor mount.
Anti chafe protection ????
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-20-2011, 11:36 AM
Default mike-
i saw that pic too--might ba an illusion, BUT chafe guard can certainly be done.
Tom
Ridgeland, SC
Old 05-20-2011, 01:43 PM
Mike S's Avatar
Senior Curmudgeon
Tom
Knowing Paul, I suspect it is got plenty of clearance.
But, just as a caution for folks looking at this thread, who might get the idea to copy the setup, ........well just wanted to make folks aware of the need to protect stuff from SS braided hoses.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-20-2011, 02:03 PM
If you can find the right size, it would be good to put tygon tubing (plastic stuff from Lowes or similar) over the steel braid for chafe protection. That's what I really like about the Bonaco hoses - Brett encloses them in the tygon for chafe protection.
greg
Greg Arehart
N 7965A
