Old 05-18-2011, 08:13 AM
avengingangel avengingangel is offline
Default spark plug type
Hi, need to replace my plugs for my ei system. its a lightspeed ignition,(i"ll check to see what number if it makes difference)
540 engine, current plug is a denso w24emr-c. Dont see it at aircraft spruce. What are others using?
thanks
Harmon Rocket II "the rockin bird"
Old 05-18-2011, 08:18 AM
I kind of believe it's a plasma II
Old 05-18-2011, 08:30 AM
looks like i could call a ktm motorcycle dealer. These plugs are used in a mini bike.lol
Old 05-18-2011, 08:56 AM
guccidude1 guccidude1 is offline
Not exactly the same EI, but I use the NGK BR8EIX for my P-Mag. Get them online or the aviation aisle of your local auto parts store. Dan
Old 05-18-2011, 09:04 AM
thank you, your number sounds close to one i crossed with the denso. it came up as a br8ecm. I'll right down your plug number too. I'm placing a quick call to aerosport to see what they recommended, i hate to bother them with something like this but figure it doesnt hurt to ask since i am no plug expert.
Old 05-18-2011, 09:25 AM
BJUST BJUST is offline
I have been getting the Denso W24emr-c plugs from sparkplugs .com for the past six years.
http://www.sparkplugs.com/results_cr...MR-C&x=61&y=15
Bayne RV9-A
Old 05-18-2011, 10:27 AM
AltonD's Avatar
AltonD AltonD is offline
Here is what Klaus has to say about spark plugs for the Plasma ignition units.
http://www.lightspeedengineering.com...Sparkplugs.htm
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 05-18-2011, 12:01 PM
gasman gasman is offline
The Denso W27 ESR-U is a cooler plug than the W24 and is better for your engine if it will work. You need to run them and then check the color.
A much lower priced replacement for the now expensive Denso, is NGK. For the W27, use NGK BR9ES. For the W24, use BR8ES. These plugs (NGK) go for about $2.45 each. But they also offer plugs that exceed the price of aviation plugs if that's what your after.
Old 05-18-2011, 03:47 PM
interesting read, thank you. Now i have the spark plug gap too, excellent.
So, what I figured is the cross plug for the 24emrc is the ngk br8ecm. These plugs are shorter. I may have a little less space than some because my engine has it's own enclosure. the longer would probably fit but I'll stick with the short.
So I'm going to go with the ngk because their local here and run around the same price. Please if anyone thinks the quality is better in the denso, or it will work better for my app then certainly tell me and I'll go with denso. Otherwise I would have kind of thought myself that the ngk should run at least equal. GTG?
Old 05-18-2011, 07:14 PM
drakerv drakerv is offline
Default plugs
I have been using the DENSO IK 27 iridium from rockauto.com.
