Old 05-17-2011, 11:20 PM
Junglepilot's Avatar
Junglepilot Junglepilot is offline
Default KT76A Grounds (pins "1-A")
Wiring up my KT76A and the King manual diagram shows "1-A" (with hyphen between as I have it) with line to traditional ground symbol. Does that mean both pins 1 and A go to ground? Or 1 OR A? I am guessing both pins should be grounds.
IF SO...can both go to the common airframe ground?
Thanks.
Sandy Toomer
Commercial, Instrument, A&P
EAA: 1023750
Based Lanett, AL (7A3)
Auburn, AL
WAR EAGLE!
Old 05-18-2011, 05:38 AM
Walt's Avatar
Walt Walt is offline
Yes, both pins 1 and A go to a comon ground.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
