Old 05-16-2011, 07:08 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Default Engine fuel pump vent line
Almost finished building. My question is where do you run the engine mounted fuel pump vent line. I have been told that running it through the bottom of the firewall to cowling flange is the way to go but that seems really close to the exhaust pipes?
Any suggestions would be very welcome. Incidentally I have a fuel injected O320 with a boost pump on the cockpit floor feeding to the Lycombing engine mounted pump.
Nigel
Nigel
RV9A-N113SQ
52F
Old 05-16-2011, 07:38 PM
cfiidon's Avatar
cfiidon cfiidon is offline
Default This is how I did mine
I mounted this aluminum tube as shown. Connected another AN fitting and tube to the fuel pump and connected the two with a fuel line rubber hose (the engine moves of course, thus no rigid line). Pretty far away from the exhaust and doesn't interfere with the cowling going on or coming off..
I have an ECI IO-360, if it matters.
<script src='http://imageshack.us/shareable/?i=dsc00784u.jpg&s=810&p=tl' type='text/javascript'></script><noscript></noscript>
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
Old 05-16-2011, 07:42 PM
N941WR's Avatar
N941WR N941WR is offline
Move it over to the left, away from the exhaust. Mine is closer to the left gear leg than it is to the exhaust.
Should your pump leak, it should be far enough way as to not be an issue.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 05-16-2011, 08:45 PM
Walt's Avatar
Walt Walt is offline
Sent you an email with some pictures...
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
