05-16-2011, 07:51 PM
My elevator lock is similar to the one Mike shows, but is a single piece and adjustable. Here's a photo of it in development:
The unit slides on the front side of the elevator. Thumbscrews allow me to tighten it down and the black bar on the left (at 45 degrees) slips down between the elevator and HS, keeping the unit from sliding off. The black stuff is plastidip to keep from scratching the paint. Once tightened down, the elevator is really locked in place so only one unit is needed.
Since I've given up on photos that have disappeared, if anyone ends up interested in this, email or PM me and I will send you a PDF with drawing and photos (updated 1/20).
greg
Greg Arehart
N 7965A
Reason: Photos gone...
05-16-2011, 09:31 PM
Nice timing on this thread Pierre...was planning to figure out control locks this weekend. I really like your approach and I think I have all the needed material on hand...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
05-17-2011, 01:29 AM
Doesn't a seat belt buckled around the stick afford just as much protection?
05-17-2011, 05:05 AM
No.
I don't like the belt around the stick because you'll have full "up" elevator that the wind can get under and a sideways wind can still move the stick left-right.
The best control lock comes from the Air Tractor factory:
BTW, this is NOT my Air Tractor.
A pin fits into a hole on the bracket that's welded to the stick. You simply lift it up and it swings back under the dash by a spring.
Yes, I only have one control lock on the ailerons and elevator of the -10.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
05-17-2011, 06:35 AM
control lock for rudder?
Great suggestions for DIY control locks for the elevator and ailerons !
Do you guys recomend the same for about the rudder?
05-17-2011, 06:52 AM
Glen,
For the rudder, I simply drilled a hole in the horn (near the rudder tailwheel link) and a hole in the stop on either side, and insert two pieces of thick wire (one on each side) bent into an upside-down U shape (this was when my airplane was a -9A). I saw this method here on VAF years ago and don't remember who was the original poster. Sorry, I don't have a photo of this handy.
greg
Greg Arehart
N 7965A
Reason: I read sam's post and needed to clarify.
05-17-2011, 07:06 AM
been here awhile
Best,
This is the type of lock I use on my RV-6. I have a photo but can't find it--the lock is made from 1/8" stainless welding rod that fits into two holes in the lower flange of the panel. The lock is attached to the stick with a length of safety wire ( I used a short bungee for a few years). Of course no lock is needed for the rudder on the tail draggers.
05-17-2011, 08:02 AM
....as long as the tailwheel steering pin is engaged!
Greg Arehart
N 7965A
05-17-2011, 08:20 AM
new and improved....
My plane 'came with' the Pierre-style hose pinch type locks. After I noticed they were leaving some black marks, I added a larger diameter clear water hose over the black fuel hose. They originally used bungee shock cord, but as that stretched, they would walk off the taper, so it seemed a big zip-tie worked as well, and was slim enough to slide between the elevator and H.stab as well!
BTW, my seat belts won't go around the stick in my -9a?....unless the buckle is right on the metal, (which I figured would chip the paint) plus I didn't like the full up elevator either, as that was the directon of the prevailing wind at the time.
As for pre-flight, I did flag them, but also thought that I should have a checklist item that says, ' ensure you have all 7 locks & plugs in the flight bag prior to flight'.....so I didn't really number each, just know that If I haven't pulled 7 things, I"ve missed one, or it's laying on the ground or in the snow!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
05-17-2011, 08:28 AM
been here awhile
That is part of our post-flight inspection, isn't it?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
