Hi Bob... what about a wheelpant installation? My -6 has it's transponder antenna installed in it's right side wheelpant (pressure recovery type). There's a BNC on the rear bulkhead of the pant. I _hope_ it's installed in the cavity in the proper orientation with a hefty horizontal piece of metal, but I can't figure any way to know short of opening up the wheelpant. Not sure how it can be reasonably grounded in this configuration, but nonetheless, it seems like it would be a great way to reduce drag... if it worked.
Unfortunately... my transponder has had pretty spotty performance, with frequent loss of mode-c. Last cross country w/flight following had problems with every controller
So I ordered a Delta Pop antenna, which I received this weekend, and it will be going into pre-existing holes behind the right gear leg.
It will be interesting to see if I slow down and/or get decent coverage. I have to wonder why the builder relocated it in the first place. If performance remains bad, I guess the KT76 is suspect.
Any history of wheelpant installations, or was my builder... experimenting?
-jon
