I have received emails from RV owners asking if Custom Flight Systems has a system that could be adapted to work on some of the nose gear models. CFS has prototype castering nose gear for the AVID and Arion Lighting aircraft. See photos at
www.CustomFlightSystems.com (caster info)
http://www.customflightsystems.com/Caster.html
The AVID caster nose gear has 8 inches of progressive spring suspension travel with 6 inches of downward movement.
11 inches of ground clearance to the tension nut at the base of the nose gear leg with a static load on the wheel.
5 inches of ground clearance to the base of the nose gear leg at full compression less tire compression.
Vertical static load testing has been conducted per FAR 23.499 at 2.25 times the vertical static load on the wheel. The dynamic load testing for the AVID was at 300 lbs this was simulated using a air ram and compressing the nose gear to the pavement at 55 mph with the nose gear off center to induce shimmy. I can post the video on
www.youtube.com if there is interest.
The gear leg is not designed to flex and the trailing link suspension can be setup to absorb 2.5 times the static load. The gear leg has a inner 4130 tube with a outer aerodynamic 4130 tube that has inner gussets that are all welded together to the tubing that makes it light but rigid.
Questions:
1.What is an approx two blade ground clearance with the standard RV nose gear using a Lycoming O-320 and O-360 or other engines?
2.Static nose wheel weight for the Lycoming O-320 and O-360 or other engines (~Min – Max range) Is 320 to 375 lbs a good range?
3.Is there data showing the force needed to bend the RV motor mount nose gear bracket?
4.What is a reasonable system failure load on the front nose gear (lbs)?
5.Full compression load on the overload springs for the CFS nose gear _____ lbs (2.25 x static)?
6.Can the RV have a slight positive angle of attack (nose high) to improve ground clearance?
7.Is there a nose gear assembly target and max weight range?
8.Is there a engine mount drawing with tube size, wall thickness and angles? (Or loaner hardware)
Thank you
Wade Schmidt
Custom Flight Systems LLC
