Old 05-12-2011, 10:37 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
Default Nutplates and Fuel Tank Sealant
I?m wondering about the sealing process of the nutplate in the fueltank rib. I get the standard sealant under the nutplate and sealing the rivets like anything else, but specifically I am thinking about the threaded cavity. Is the screw/bolt providing sufficient sealing or is sealant added into the thread as the bolt/screw is inserted and tightened? The only other way I can think of doing a seal would be to create a sealant ?bubble? on the nut side that provides room for the screw to insert and go past the nutplate but not penetrate the sealant. That sounds a little far-fetched so I wanted to check how I should be doing this. Specifically it?s the nutplates and screw for the fuel senders.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
Old 05-12-2011, 10:44 AM
beav's Avatar
beav beav is offline
Default Use NAS1473-A08 nutplates
I upgraded those nutplates to NAS1473-A08 that have an integrated O-ring and a chamber on the back for the screw:
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 05-12-2011, 10:49 AM
Where did you get those from?
RV-10
N928MT
Build Project Site
Old 05-12-2011, 10:54 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Default Wick's has them..
http://www.wicksaircraft.com/catalog...381/index.html
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 05-12-2011, 10:55 AM
Wow, that's one spendy upgrade/nutplate.
RV-10
N928MT
Build Project Site
Old 05-12-2011, 11:09 AM
rocketbob's Avatar
10+ years of flying with standard fuel tank covers (prosealed) with a dab of proseal on top of the screws, and never any leaks.
Tank rivets are another story.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-12-2011, 11:26 AM
beav's Avatar
Only 0.1% of the cost of the plane :-)
jason
jason
N4VR
RV-7 (Flying)
Old 05-12-2011, 12:39 PM
terrye terrye is offline
Default NAS1473-A08 nutplates
Yep, that's what I used.
Upside:
1. Made for the application and I'm sure they won't leak through the threads.
2. Much easier to remove the tank inspection cover in the future without proseal all over the screw heads.
Downside:
1. Expensive!
2. They still have to be prosealed on the tank side at the rivets.
3. The standard Van's fuel pickups (not the aerobatic flop tubes shown in the photos) interfere with the nutplates. I had to make a special bending tool to put a bend in the vertical portion of the fuel pickup tube.
Old 05-15-2011, 08:40 AM
I'm going to be using the Princeton Electronics fuel senders (Capacitive) and wonder how the seal on the screw will work. Is this technique inserted the screw and the pro sealing the head of the screw? So it's not so much sealing the threads, just the head?
RV-10
N928MT
Build Project Site
Old 05-15-2011, 10:38 AM
Walt's Avatar
Walt Walt is offline
I also recommend these nutplates, I used the -10 size so I could use a 3/16 hex bolts in place of philip screws.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
