Go Back   VAF Forums > Main > Safety
  #91
Old 03-20-2019, 06:15 AM
snopercod's Avatar
Originally Posted by F1R View Post
...an over temperature / fire detection and alert system near the cooing air exit would provide improved odds of a faster reaction and landing.
I have one of those. It's a $13 digital meat thermometer with the probe stuck through the firewall. It doesn't have an alarm so would only serve as confirmation of a fire. I also installed a 3/8" aluminum tube "spray bar" in front of the firewall which is plumbed to a fitting on the panel into which my Halon fire extinguisher nozzle fits. I hope I never have to use those things.
(2020 dues paid)
Old 03-20-2019, 07:19 AM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Koolmat
Does anyone have experience with the Koolmat product for the front side of the firewall. I have seen the installation of Fiberfrax with stainless sheet riveted onto the firewall, but am not a big fan of the pillowing look.
Was curious if anyone had any experience with Koolmat's ease of use for installation. My thought was to adhere it with Firebarrier 2000+ then attach my components to the firewall through the koolmat (except those that need grounding as they would attach directly to the firewall) to help hold it should the firebarrier 2000+ fail to hold it in place.
I would of course do all the other sealing as recommended. This would simply be in addition to everything else like many of you have done. Thoughts?
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Research In Progress
Old 03-20-2019, 09:41 AM
DanH's Avatar
DanH DanH is offline
Roughly 8X heavier and not nearly as effective in any parameter.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-20-2019, 12:10 PM
rv7charlie rv7charlie is offline
IIRC, there have been tests showing that halon in a piston engine cowl can't compete with the hurricane of cooling air, and just blows out the exit. I'd be more prone to save the halon for me. :-)
Old 03-20-2019, 04:09 PM
Checkmate's Avatar
Checkmate Checkmate is offline
Default Thicker SS?
No Koolmat experience but maybe consider using thicker SS. I used .005 SS Shim Stock, 1/8" FiberFrax, 3M Barrier 2000+. No wrinkled tinfoil look like the thinner stuff but some oil canning is to be expected around the areas where you attach items over it. Also a hydraulic punch works great for making nice clean round holes. Ordered everything from McMaster-Carr.
See Photos below
https://lh3.googleusercontent.com/0G...c=w800-h450-no
https://lh3.googleusercontent.com/VH...I=w450-h800-no
https://lh3.googleusercontent.com/YT...=w1608-h904-no
https://lh3.googleusercontent.com/99...l=w800-h450-no[/quote]
Ed
RV-9A - Down for Panel & Engine Conversion
1946 Piper J-3 Cub - Flying
VAF Donation Paid Feb. 2020
