05-08-2011, 05:17 AM
Yesterday.
The Race-to-Ridgeland started as I crossed the line at 9:02 a.m, WOT and the revs dialed back a bit. The 128 mile course used 4 airports in a rough rectangle shape, which my -10 completed in 45 minutes or so, top time of day!
A retractable Lancair 360 placed next, 45 seconds behind! The second airport was overcast, variable at times to broken and since we had to make a 360 minimum, at the turn points, the Lancair made several at one airport in order to try and see the ground, costing him valuable time. I lucked out and saw the airport through a hole and went on.
Interestingly, my Dynon showed a continuous TAS of 214 MPH, occasionally topping 220, indicating 210 MPH at 1,000' for the whole trip...3 MPH faster than last year. CHT's maxed out at 402 deg and oil was 205F. I had fiddled with different RPM's and found the fastest one in transit to Ridgeland from home.
Then on to Peachtree City to Falcon Squadron's wonderful fly-in with over 50 RV's...every model present! A good day indeed!
Tom Swearingen (TS Flightlines) was at Ridgeland and quickly proceeded to slice and section my fuel hose that had the firesleeve burned through, (he made it) to see its internals. Several of us were amazed to not see any blistering or failure mode of the teflon liner! If it had been rubber, we would have been toast, more than likely.
I'm a bit rushed for Church happenings but I have several pictures of the insides of the hose that I'll post this afternoon.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
05-08-2011, 08:59 AM
Senior Curmudgeon
Congrats!!!!!!!!!!!!
I would love to have seen that grin
Best,
The fuel flowing through it will keep the temp down------how much, or how long, I have no idea, but it is a factor.
You can boil water in a folded business card, over a candle----till the water is all gone, then the card burns up.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
05-08-2011, 10:31 AM
Mike...
You had a little too much time sittin' around the station!!  Now you know that I am going to spend my day trying that!
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
05-08-2011, 11:01 AM
Senior Curmudgeon
Originally Posted by jetjok
Mike...
Fire physics course in Ione-------1977.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-08-2011, 11:35 AM
Pierre,
Were you guys not allowed to use GPS? If not wouldn't that have shown the airports?
Congrats, BTW..
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
05-08-2011, 12:52 PM
I did use my GPS.
I had the airports/checkpoints from last year as a flight plan, in my 430W, named R2R and simply activated it.
I did the turns manually and hardly lost any TAS, then re-activated the auto-pilot for that leg.
I had also experimented with the winds aloft on the way over there and knew to fly low going north and the 1500' southbound legs gave me an added 15-20 MPH GS. Enough to win by 45 seconds over the Lancair.
The rest is secret
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
05-08-2011, 01:17 PM
Don't worry Pierre I will be back one of these days!
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
05-08-2011, 01:22 PM
Senior Curmudgeon
Sure hope so, looking forward to it.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-08-2011, 02:13 PM
Congratulations again on your win, Pierre. Your trophy is in the Ops building waiting for you tomorrow.
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
05-09-2011, 05:08 AM
I've already raced you Todd.
Before your airplane burned, I was 15 MPH faster, so you'd better put a Lyc in the next one, not the Corvette lump
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
