Old 05-07-2011, 06:53 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default Leading edge prop tape question
I've got a Catto 3-blade prop and I'm (finally) getting around to putting the leading edge prop-guard tape on it. I was about to do it today, but I was slightly confused by the very long instructions. This is the kit that you buy for ~$50 at ACS.
The point in question is whether or not I need to use the adhesive accellerator. There is a blurb on the back of the instruction sheet that gives drying times. 24 hours with the accellerator, 48 hours without (on a polished prop). Does anyone have any suggestions about this?
Thanks!
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-08-2011, 08:05 PM
Wow, really...no one?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-09-2011, 02:38 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Default Accelerant
Thanks!
I used the accelerant for my instal so I don't know. Contact the Mfg and let us know what they say.
Old 05-09-2011, 06:46 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
If the accelerant was an extra purchase, I did not use it. I used the items that were supplied with the original kit.
It's probably been on the prop for about a year with no delamination.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 05-10-2011, 08:14 PM
Nope, the accelerant came with the kit from ACS. I called Craig today and asked what he thought of using it, and he said to use it. He also e-mailed me his own instruction set for installing the prop-guard tape. Pictures included! Awesome customer service!
Sonny W
Boise, Idaho
RV-7A Flying!
Old 05-11-2011, 06:42 AM
Jimd Jimd is offline
Sonny,
Would you mind sending me that e-mail from Craig? I put some vinyl tape on last summer but it did NOT stay on too well. It was a field install so I was actually happy with the way it worked, but would like to try it again using his instructions.
Jim jdelveau (at) msn (dot) [com]
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 05-11-2011, 06:51 AM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
I can't say how it would be if you didn't use the accellerant; I used it on mine. It was a real pain getting it to follow the curve on a scimitar prop. I had to cut a notch on the back side of of the tape about eight inches from the end of each blade. Even with the accellerant, there was plenty of time to do the job.
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 05-11-2011, 07:41 AM
Jim, I just e-mailed it to you! I hope Craig doesn't mind. Let me know if you don't get it.
Sonny W
Boise, Idaho
RV-7A Flying!
