Go Back   VAF Forums > Activity Specific > Aircraft Camping
  #11
Old 05-09-2011, 08:23 AM
Bob Gordon's Avatar
Bob Gordon Bob Gordon is offline
I cut 16" diameter pads out of 1/2" plywood. Stick them in front of each wheel and roll forward another 8" or so. No sinkage, not even last year in HBC. When leaving, I just threw them in the local dumpster.
Bob Gordon N681GP
RV6 @ Concord, NC KJQF
KE5WZK
Old 05-09-2011, 10:29 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I used some scrap 0.50" 5052-H32 I had in the bin and folded up a couple pads about 12x6. Put 0.75"(ish) flanges on all edges to stiffen it up. Worked great, and due to my less than precise bending, they sorta nest. Took about ten minutes. (helps if you have a kick shear, notcher and pan brake in your hangar!).
The only problem is that you almost need chocks because the tires want to roll off if the ground is not perfectly level.
Mike W
Venice, FL
N164WM
Old 05-09-2011, 05:20 PM
GusBiz's Avatar
GusBiz GusBiz is offline
Default Nice paint Job
Actually Chris, do you have pictures of the rest of your aircraft?
It looks like a great paint job.
Would love to see it.
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
Old 05-09-2011, 09:45 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Follow the link below Gus. Thanks for asking.
Chris
https://picasaweb.google.com/pratt.c...IDti5jwz-2LcQ#
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 05-14-2011, 04:00 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Are the downspout devices solid on the bottom? If not, then in wet conditions they may still sink.
Old 05-14-2011, 09:37 PM
chrispratt's Avatar
Super Moderator
No they're not Ron, so we'll have to see how they fare.
Chris
N898DK
