Old 05-07-2011, 09:42 AM
Norman Norman is offline
Default Side Tone GNS430W
I am having difficulty getting a Side Tone adjustment to hold. The manual says to ENT on ?Store Calibration?? but the Store Calibration is ?greyed out? and the cursor will not land on it.
I have spoken to Garmin Tech support who say there has been a recent change and now it is a dealer only setting. I called the dealer and they had never heard of a dealer only setting, they called Garmin who said I had the wrong info, and to try switching off the unit and break both fuses. I?ve done this and the setting still will not hold. Can anyone help?
Many thanks
Norman
RV9
Old 05-07-2011, 12:11 PM
Radomir's Avatar
Radomir Radomir is offline
Norman, it's in the instructions You have to first choose one of the 3 frequencies.. side tone can be adjusted only when those are selected (on that same screen)... Only then will the Store calibration be available... Do it for all three frequencies..
Radomir
RV-7A sold
Old 05-07-2011, 03:52 PM
vic syracuse vic syracuse is offline
Super Moderator
Radomir is right. The frequencies are 118.00, 127.00, and 136.97. Once you enter those frequencies you will see it is not grayed out any more.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 05-08-2011, 04:55 AM
Default Thank you
Vic and Radomir Thanks
I should have adopted the old saying 'If all else fails read the instructions'
All working now.
Norman
Old 05-09-2011, 08:01 AM
bkthomps bkthomps is offline
forgive my ignorance, what is sidetone?
Old 05-09-2011, 08:20 AM
Walt's Avatar
Walt Walt is offline
"forgive my ignorance, what is sidetone?"
It's when you hear yourself in the headset during transmit.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-09-2011, 08:31 AM
ah, i guess i've never experienced sidetone
Old 05-09-2011, 08:55 AM
Walt's Avatar
If you wear a headset you have heard it. It's the same thing as hearing yourself when you talk on the intercom, if you didn't hear yourself talking at the correct volume level then you talk much louder than normal so you can hear yourself. Ever hear somebody shouting when they have earplugs or headset on? This is do to the lack of aural feedback. The term "sidetone" refers specifically to this feedback durning the comm transmit function.
