Old 05-07-2011, 08:53 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default SD20 Spline Drive
Of course I discover something after close of business. I am installing the 3/4" extension to the vacuum pad, the kit comes with a longer spine drive coupler (green bit) for the SD20. The spline drive shaft fits on the the coupler via 8 studs built into the spline drive. My dilemma is that 4 of the studs have a little elongation on them, which I suspect holds the drive to the coupler so it can't fall out.
I know some of you have installed this kit, what is the trick to getting the drive off the coupler? The green part seems to stretch but I don't want to destroy the drive. Unlike the other products from B&C this does not come with very good instructions (the extension kit).
Thanks for any help, I am hoping to get something done on this over the weekend.
Cheers.
Here are the two couplers, I need to move the drive from one to the other
This shows the elongation, essentially that stud has a little tab built into it so it overhangs after inserting it.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 05-07-2011, 09:04 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
It looks like there are 4 studs attached to each part, and if you separate the parts, you will then be able to push the studs out of the short green part, and move them to the long green part.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-07-2011, 09:19 AM
RVG8tor's Avatar
Default One piece
Mike
The drive spline (all the black parts) is one piece. I can slide it down on the studs more and can see the little elongation (tab) but no clue how this was installed let alone get it removed.
I like puzzle keeps the mind healthy but I don't like wasted time I do that on my own well enough. Hopefully someone who has installed this kit will chime in.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 05-07-2011, 09:32 AM
Mike S's Avatar
Senior Curmudgeon
Sure does look like the drive pin with the peened over head is fitting into a "U" notch, are all four of the peened heads matched to notched areas in the splined piece?
I suspect the green piece will slide off the fixed drive pins, and will have 4 pins come along for the ride.
The large center shaft will probably stay with the splined part, and the green part slide off it.
The green piece is a rubber or plastic part correct?? it is a shock absorber if I am interpreting the photos correctly.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-07-2011, 10:53 AM
RVG8tor's Avatar
Default it is one piece
I don't have a picture but even though the stud with the tabs have a cutout at the base, if you look on the underside it is one molded part.
I am wondering if one could just pry it apart since the green part is stretchy.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 05-07-2011, 06:33 PM
aerhed aerhed is offline
Thats normal for Airborne type shear couplings. Your green spool will stretch over the nub. Use a flat blade under it & twist to pry it up...carefully. It helps to have the coupling warm. You could use hot tap water, nothing hotter.
Actual repeat offender.
Old 05-08-2011, 01:45 PM
RVG8tor's Avatar
Default Hot Water
Thanks for the tip, hot water for about 2 minutes and it slipped right off.
Cheers
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
