  #11
Old 05-07-2011, 01:16 PM
Phil's Avatar
Phil Phil is offline
I'd add a doubler on the inside of the skin that returns the opening to the proper shape. Then I'd build up the recessed area with microballoons until you get it flush with skin.
Old 05-07-2011, 01:47 PM
Pat Stewart Pat Stewart is offline
The proper repair is a nickle/dime patch. I think thats what Patrick (flion) was trying to describe. To keep the explanation simple its basically an internal doubler that is larger than your current opening after you square it up. The next step is a piece of skin cut to match the opening and the same thickness as the damaged skin riveted to the internal doubler. After riveting both skins you can cut your duct opening again. The seam can later be filled with micro balloon and sanded for paint.
Piece of cake.
Pat
Old 05-07-2011, 04:59 PM
Seansull's Avatar
Seansull Seansull is offline
Thanks everyone for the great ideas and instruction. I will post a few photos of the finished product very soon.
I really appreciate this group and the wealth of knowledge that is here!
Sean Sullivan
N116EX (reserved)
RV10 - SB Wings, Emp Complete
Builder #40919
Fort Worth, TX
www.iRV10.com
EAA Chapter 34
http://www.eaa34.org/index.htm
Old 05-07-2011, 06:14 PM
curtis's Avatar
curtis curtis is offline
Instead of resin and micro I would recommend using tank sealer to fill any gaps. I work for a large aircraft plant in Wichita, KS and we use ProSeal to seal gaps on panels and fairings on the aircraft after installation. It remains flexible and it is paintable.
RV-6A Slider
550 hours +
Build it light and cheap
Old 05-07-2011, 06:15 PM
aerhed aerhed is offline
Default ELT access
Perfect opportunity to make an access hole. Just tell everyone its for ELT access. Oops, too late you already posted.
Actual repeat offender.
Old 05-08-2011, 10:01 AM
johngoodman's Avatar
johngoodman johngoodman is offline
NACA vents come in different sizes - how about getting a large one? Here is a place to start:
http://secure.chassisshop.com/partlist/6015/
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 05-13-2011, 09:59 PM
Seansull's Avatar
Default Here is what I came up with......
Thanks again for all of the great ideas! You guys are awesome.
I basically took a little bit of everyones advise along with a few of my own and came up with a fix that I think will look just fine. I still need to sand my micro balloons then prime and sand a few times. After that, I am pretty confident that I will be the only that knows this is a fix. Thanks again!
Sean Sullivan
N116EX (reserved)
Builder #40919
Fort Worth, TX
www.iRV10.com
EAA Chapter 34
Old 05-14-2011, 05:07 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Great Job!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 05-14-2011, 08:12 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I've said this many times - the real art of building is knowing how to turn your own mistakes around into a success. Anyone can buy a new part when they mess one up - a true builder can fix most mistakes to established standards. Good job!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
