Old 05-06-2011, 02:22 PM
rapid_ascent rapid_ascent is online now
Default VS-410 Flush Rivets
Hi gang,
I have had some trouble with the flush rivets that attach the VS-410 to the Rear Spar. Specifically the rivets that are very near the bend in the hinge bracket. I now have all of them set, but I'm questioning whether I need to redo some of them. I'm afraid this falls into the category of if I do it again it may be worse. I've attached a couple of pics for comments from the more experienced builders. So the question is do I leave it as is or try to make them better.
Thanks in advance for any comments.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 05-06-2011, 07:57 PM
KayS KayS is offline
for me they look OK, so i would leave them like they are. but maybe you will hear other opinions here. if you really feel uncomfortable... you could replace them with cherry max rivets.
is it possble that the distance between your brackets is to big?
Kay
Old 05-06-2011, 08:06 PM
apkp777's Avatar
apkp777 apkp777 is offline
Leave them. They are fine.
Tony Phillips
N524AP, RV 9 (tail wheel)
