Go Back   VAF Forums > Model Specific > RV-6/6A
Old 05-01-2011, 11:42 AM
meanstreakii meanstreakii is offline
Default gear leg mount
has anyone every experienced stress cracking on main gear leg mounts (dynafocal engine mount) - cracking is on front (propeller side) and runs up/down, both legs are about the same (1 inch long)???
Old 05-25-2011, 05:23 AM
RV6AussieNick RV6AussieNick is offline
Default Eng mount cracking
I've herd this is a common problem, the guy who built my RV-6 had the eng removed and the eng mount removed to CO a mod the repair and stiffen the lower corners around the gear leg mounts, I'm in the middle of rebuilding the aircraft, when I inspected the eng mount I too found cracking at the lower corners adjacent to the gear mount tubes.
Hope this helps..
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 05-29-2011, 10:05 AM
gbitzer's Avatar
gbitzer gbitzer is offline
Default Gear leg mount
I had the same at roughly 500 hours. I live on a grass strip. I had heard that this is more common in the UK due to the number of grass strips. The fracture in the weld was accessable with removing the engine. I was able to locate a welder who build race cars and also airplanes. He was able to TIG weld the junction. No mods were made to the mount and all is good 600+ hours later.
Good luck.
