04-30-2011, 10:47 PM
How to apply torque seal to AN and NPT fittings?
Two questions:
- Does anyone have a picture of how to correctly apply torque seal to an AN fitting nut?
- Same question, but for an NPT fitting.
The reason I'm asking is that I've heard you shouldn't apply torque seal to threads, but I don't know how to do it otherwise in these applications.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
05-01-2011, 12:17 AM
It's not a thread sealer
Torque seal is applied to the nut (AN fitting) in such a way that it will be chipped of when a spanner is placed over the nut or the fitting is turned as in removing the fitting. The main thing you want to do is have it where you can see if the fitting is loosening or has been tampered with.
If you look I'm sure there is an approved application process somewhere on the net.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
05-01-2011, 02:41 AM
Thanks Nick. Reading your response I can see I wasn't very clear in my original question. Sorry about that. I understand it's not used as a thread sealer.
I'm trying to figure out whether the torque seal goes from the edge of the nut to the AN fitting (gets on the visible threads), or from the back side of the nut to the sleeve, or from the back side of the nut across the sleeve to the tube.
For NPT fittings...say, for example the ones screwed into the parking brake valve...Would I be correct in putting a dab of torque seal from the exposed NPT thread to the valve body?
Mike Cencula
RV-7A (fuselage)
www.our7a.com
05-01-2011, 03:18 AM
It doesn't really matter where it is placed, the thing that you want to achieve is that it will be visible and that if the fitting is starting to rotate or someone has tampered with the fitting/bolt you will be able to see that.
Nick Purcell
05-01-2011, 04:01 AM
Apply it after you have torqued each fitting.
It is easy to torque a bunch of fittings and possibly forget one then apply torque seal to them all. I probably go a little overboard with torque seal as we did in the military. I run a bead across 1/8" of tube onto nut then across to fitting. I apply it to the most visible side once everything is assembled.
Good judgment comes from experience, and a lot of that comes from bad judgment.
05-01-2011, 08:21 AM
Mike, to answer your question, just put to on the threads. It's not a big deal to remove the seal if you have to remove the nut/fitting later.
-Rob
Rob Kochman
RV-10, Flying as of March 2011 ( blog)
Paine Field (KPAE)
EAA Chapter 1440
05-01-2011, 08:37 AM
EAA has a video that explains the proper method:
http://www.eaavideo.org/video.aspx?v=29739769001
Joe Schneider
RV-7, IO-360, BA Hartzell, N847CR
Flying since 2008
05-02-2011, 12:49 AM
I think the latest EAA Mag had an article about things DAR's look for (attention to detail) and it specifically mentioned NOT getting TS on the threads, but on the nut/sleeve only.
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
05-02-2011, 08:28 AM
I disagree with this. It's one thing to not get torque seal on threads that pass through a fastener, like a nut, but if you don't put it on the threads of a fitting, where will you put it? The former case might cause galling of the threads (though most lacquer applications remain so brittle and stick so poorly I don't think it would be a problem on most areas of the airframe) but the latter has no chance to cause a problem as the fitting is already tight and the B-nut will only go away from the threads with lacquer. Of course, if it bothers you, you can always go with safety wiring the fittings, in which case you don't need torque seal.
EAA Technical Counselor #5357
