04-30-2011, 07:00 PM
Really Stupid Question
When flying a experimental aircraft what is the proper call sign to use with the FAA for filing flight plans or picking up flight following. Is it required to use Experimental with the call sign or is the N number acceptable.
George
04-30-2011, 07:13 PM
Senior Curmudgeon
This has been discussed a few times before
There is no solid answer--------we have a few controllers on the forum, and they are not consistent in their answers, it seems to be a local area preference.
There are FARs that deal with it, but again, the comments from the controllers have not always been in line with a strict interpretation of these regs either.
And before someone gets the idea I am bashing controllers, not so.
One of my neighbors who is a retired controller gave me a bad time for using "experimental" in my radio calls-------and another buddy who is a controller says to use it in the initial contact, then no more.
Around here (central Calif) most folks use "RV" and the N number, most of the local control guys know what an "RV" is.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Paragraph (28) of operating limitations:
"The pilot in command of this aircraft must notify air traffic control of the experimental nature of this aircraft when operating into or out of airports with an operational control tower. When filing IFR, the experimental nature of the aircraft must be listed in the remarks section of the flight plan."
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-30-2011, 07:19 PM
You can use the search function and search on "experimental call sign" to see a lot of previous discussions.
Here is a link to one of the longer threads.
Happy reading.
http://www.vansairforce.com/communit...ntal+call+sign
Mark Beattie
Anaheim, Ca.
RV6 fuselage in work
N642ML reserved
04-30-2011, 10:00 PM
Mike,
You got a problem with controllers?
04-30-2011, 11:45 PM
Senior Curmudgeon
O.K., I'll take the bait
Originally Posted by tkatc
Mike,
No, not at all.
Said so in my first post.
My reference to them is based on who I feel should be looked at as an authority in questions like this------nothing more.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-01-2011, 05:37 AM
Just messing with ya, Mike. I think your original answer was spot on. If the controllers can't even agree on it, it is probably one of those never ending debates and each opinion has valid reasons as to why or why not.
05-01-2011, 09:32 AM
Senior Curmudgeon
Thanks Tony
Gosh, I just love hearing that
For those who have not seen Tony's thread "Ask a controller" this and a host of other questions are discussed.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-01-2011, 09:44 AM
Another stupid question
Wouldn't this just go away if we used NX registration numbers?
Actual repeat offender.
05-01-2011, 10:45 AM
First off, you can't use "NX" numbers unless you aircraft is over 30 years old or is a replica of one over 30 years old.
Secondly, the "X" is not part of the registration number and is never used in any paperwork or verbal communications.
The "X", when used, simply replaced the "Experimental" placard on the aircraft.
