An older copy of "Airplane Performance, Stability and Control," by Perkins and Hage, contains an excellent and easy-to-use section that includes this sort of thing.
You'll need to assess the characteristics of the existing plane and compare those to the revised plane. In general, what you're describing will reduce the stability of the airplane, especially at higher power settings.
Dave
