Old 04-29-2011, 08:40 PM
Wesael's Avatar
Wesael Wesael is offline
Default Performance Engines
Do any of you have experience with this company?
http://www.performanceengines.com/
Can any of you share your experience with having a camshaft re-ground for more performance in the 23-2400 RPM range?
Weasel
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
I have changed my User Name to the correct spelling as it became availible. Please direct all correspondence to Weasel
Old 04-29-2011, 10:40 PM
jrs14855 jrs14855 is offline
Default cams
Unless you are planning to race at Reno, trying to improve on a four cyl Lycoming cam is a waste of time and money. Performance has a very questionable reputation. Stick with the shops like Barrett and Mattituck.
Old 04-30-2011, 09:06 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default performance increase
I do not have any experiance with that company. For performance parts & service I recomend Lycon aircraft engines. I do not think that a cam upgrade alone will provide a useful performance increase. Engines are or should be a matched system. Changing one item will not help unless that one item was miss-matched to the system. If you want to increase the performance of your engine I would have your cylinders ported & polished, high compression pistons installed, custom ground cam matched to other engine componants, high flow exhaust system, and electronic ignition with timing curve matched to engine componants. Remember engines are air pumps, more air in & out = horspower. With this aproach a 320 based lycoming can produce well over 200HP with normal RPM's and engine life.
Good Luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
