Garmin 696 Video Output
Not that I know of, but you can sure use the screen capture capability to capture any screen image to the inserted SD card and use these images in a presentation.
Select MENU, MENU, SYSTEM SETUP, DISPLAY, MENU, Enable Screenshot. You can then press and hold the joystick to capture the current screen image to the SD card.
Steve
