Old 04-28-2011, 07:36 AM
crabandy crabandy is offline
Default Acid Etch for 410 filler?
Should I acid etch the alumimum prior to applying west systems 410 filler? If so where can you find acid etch locally.
Andy
Old 04-28-2011, 07:58 AM
newtech's Avatar
newtech newtech is offline
On mine, any aluminum that got filler was cleaned with Dawn and maroon scotchbrite pad followed by acid etch and alodyne. No filler has fallen out so far
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 04-28-2011, 03:32 PM
Adam Adam is offline
Acid is ok but I would be more agressive with the Scotchbrite, I used 60 grit paper.
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
PAID 2021
Pittstown, New Jersey
Old 04-28-2011, 05:36 PM
Prior to sanding I wased with soap and water than sanded with 60 grit, washed with soap and water than acetone. As I was sanding the fiberglass down, there was one section of fiberglass over the aluminum that I ended up peeling off with a putty knife. Possibly it's my cleaning, half the parts I wiped with acetone and papertowels until the towel came away clean, the other half I just wiped down once with acetone and paper towels.
Old 04-28-2011, 05:53 PM
APACHE 56 APACHE 56 is offline
Default Where's the etch?
[quote=crabandy;537517] If so where can you find acid etch locally.
I found the metal prep (acid etch) at our local automotive paint stores.
Don
Don Stiver
RV8 "Little Pill" N6371S, Merritt Island, Fl.
BPE IO-390, Dual P-mag, MT 3-blade, AFP system
Steen Skybolt: Sold
Old 04-28-2011, 07:01 PM
bret's Avatar
bret bret is offline
Did all my tip work by sanding with 80 grit, blow air, grease and wax remover and apply, worked great! I used west systems G flex resin,
Old 04-29-2011, 06:23 AM
Wayne Gillispie Wayne Gillispie is offline
Default I ordered the 860 acid etch kit from
Jamestown Distributors.
It improves the bond strength and helps prevent corrosion which can form at the metal/epoxy interface. Corrosion can cause a weakened bond down the road. I used it for some but not all alum/epoxy bonds. Mainly on winshield base fairing as it was recommended by Van's here. Here is a link.
http://www.jamestowndistributors.com...t.do?pid=12214
Good judgment comes from experience, and a lot of that comes from bad judgment.
