Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #41
Old 06-09-2011, 09:27 PM
Great. That's pretty much what I figured.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 06-10-2011, 11:12 AM
ninerhawk ninerhawk is offline
Default O-ring source
I checked with Precision Airmotive on the specific part number for their version of an O-ring, which they said could be used in conjunction with an AN815-4 union (straight fitting) on the Silverhawk fuel outlet. That is a Precision part number 951787 whcih they claimed would be available through a Precision distributor.
Anybody found a $hipping friendly source for that o-ring?
Howard Kaney
RV-9A
West Bend, WI
fuselage/FF
Old 06-10-2011, 11:45 AM
Default Whats the dimensions
of the o'ring? Surely Spruce or GAHCO has them.
Tom
Ridgeland, SC
Old 06-10-2011, 03:38 PM
Lars Lars is offline
Parker's number is 3-906 for the correct o-ring to fit a 3/8" o-ring boss fitting that meets MS33649.
McMaster-Carr's aviation department sells them as part number 1201T294, $14.82 for a bag of 100 in mil-spec Viton fluoroelastomer.
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 06-16-2011, 08:38 AM
Since it's never been used, I just took the O-ring off the fitting that was on there, and put it on the new one. That's OK, right?
Bob Collins
St. Paul, MN.
Old 06-16-2011, 09:39 AM
Most likely. As long as it wasn't cut or nicked, it'll work. Obviously an inspection item (around the fitting, for leaks) after you get the engine running, but it would be in any case.
Lars Pedersen
Davis, CA
