Old 04-27-2011, 12:18 PM
rkochcyxh rkochcyxh is offline
Default Oil Coolers
I'm put an IO360 in my RV9A. It is rated at 180hp. My question is on oil coolers Vans offers the Cooler II or the Cooler 20006A. Will the Cooler II do the job in keeping the oil temp in check. We can get hot during the summer. Probably not as hot as Texas or Arizona but still close to 100 F.
Thanks guys
Russel Koch
85% done 90%to go
Old 04-27-2011, 05:58 PM
db1yg's Avatar
db1yg db1yg is offline
Hi Russel,
I would delete the Vans cooler and go with a Stewart Warner 8406R. It is the same size as the stock cooler that Vans sends in the kit but has greater cooling efficiency. It should do the trick on your 180/9a even in hot summers.
You are gonna love that engine/airframe combo! Climbs great (even with a fp prop) and the wing allows very efficient high altitude (low to mid teens) cruise operation.
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 04-27-2011, 06:49 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
Even the SW8406R won't cool some 360s. My friend who just finished his IO-360 RV7 a couple months ago is having to replace his 8406 with a bigger cooler now that spring/summer temps are coming. On the RV-8 in my avatar (ECI IO-360 9.2:1 compression) we had to go with the SW 10599R to keep it cool, and it can still break 210 deg in a climb on hot days. 9 or 10 rows on the oil cooler seems to be the minimum number you really need on a 360.
Neal Howard
Airplaneless once again...
Old 04-28-2011, 08:28 AM
N941WR's Avatar
N941WR N941WR is offline
The "stock " cooler worked great with my O-290 but doesn't seem to work so well with the O-360. I ordered th S-W cooler but it will be a few weeks before I can test it and give you a PIREP.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-28-2011, 08:44 AM
Walt's Avatar
Walt Walt is offline
The SW8406R is what I run and I know alot of other folks run the same cooler with excellent results on the 360. If you run piston squirters then you will probably need the larger cooler. My normal temps are 180 and I rarely see over 210 in the dead of summer (110+).
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-28-2011, 09:02 AM
Brantel's Avatar
Brantel Brantel is offline
Stock Van's on my O-360 FP. No piston squirters.
180?-195?F depending on OAT.
Works great!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-28-2011, 11:37 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Works great!
With a C/S, but other than that...............has just worked fine, and same general temps. Even have the Van's shutter for winter.
L.Adamson --- RV6A
Old 04-29-2011, 06:09 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I never had any cooling problems with the Van's stock cooler on an 0-360 A1A with C/S prop on a 7A.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 04-29-2011, 06:06 PM
Thumbs up Larger of the Two
Thanks Guys,
After reading everybody replies I think I will install the larger oil cooler that Vans offers. The "2006A" is also designed for the I0-360 200HP and the IO-540. I place an order with Vans every couple of weeks so shipping should be no problem. The "2006A" is larger than the Cooler II and I'm hoping it will do the job. The whole engine setup is an I0-360 from Aerosport in Kamloops B.C. With an Eagle EMS System and a Whirlwind Ground Adjustable Composite Prop. I'm hoping to set the prop for cruise and stay between 6500 and 10500 for my altitude. The nice thing about building your own airplane is that if I don't like the setup(oil cooler) I can always change it. Thanks Again Everybody
Russel Koch
RV9A
Doing the fiberglass tips on the empanage this weekend.
Not yet flying, but getting closer every day.
