Old 04-18-2006, 05:43 PM
AX-O's Avatar
AX-O AX-O is offline
Default Is MEK not legal in Cali?
I went to buy some MEK at NAPA auto store where I got my primer and they told me that MEK is not legal in Cali. Is that true Seems like many people here use it to clean parts prior to priming. That is the reason I wanted it. He told me that I can use brake cleaner. I told him that I would pass on the brake cleaner but when I built the practice tool box I used the cleaner (had a can at home). Worked fine I guess but the smell was out of control and I was outside. Water and sope sound kind of weird to me. Why would you add water to a part that has no corrosion resistance (after using the SB pad)? Can I use paint thinner? I don?t want to open a can of worms here. Just wanted a little help.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-18-2006, 05:47 PM
Richard Suffoletto
Posts: n/a
Default MEK in Calif
I buy MEK at Home Depot so It must not be banned in CA
Old 04-18-2006, 05:48 PM
jcoloccia jcoloccia is offline
I buy mine at Home Depot and Lowes. Perfectly legal as far as I can tell.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 04-18-2006, 05:50 PM
jsherblon's Avatar
jsherblon jsherblon is offline
They sell MEK in lots of stores around here (south of Sacramento) including Lowes.
I don't get the NAPA thing. I went to the local NAPA auto store to buy some of the self-etching primer. The guy told me it was illegal for him to sell paint in a spray can. I went across the street and bought Dupli-Color in a rattle can and see it everywhere in stores around here.
Jim Sherblon
-7 Slider Finishing Kit
Stuck in Lodi CA
Old 04-18-2006, 06:04 PM
mgomez's Avatar
mgomez mgomez is offline
Default Is brake cleaner legal in CA?
I thought brake cleaner causes cancer in California?
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 04-18-2006, 07:22 PM
RScott RScott is offline
Yes, MEK causes cancer in California, but only in California.
They also want to ban water because it is the leading cause of drowning.
Old 04-18-2006, 07:43 PM
Mel's Avatar
Mel Mel is offline
MEK is pretty nasty stuff. Laquer thinner is adequate for 99.999% of all cleaning.
Mel...DAR
Old 04-18-2006, 08:34 PM
briand's Avatar
briand briand is offline
I think its highly regulated (not banned) in CA. I work for a big company that bought a factory in LA and I know they quit using it at that LA plant years ago (it was still being called out in many of the processes) because of all the regs. The average joe can use it because CAOSHA or what ever they are called there doesn't regulate us in our homes.
Old 04-18-2006, 11:38 PM
osxuser's Avatar
osxuser osxuser is offline
I bought it at OSH. We use a ton of it at our shop too. I don't expect the fumes to be much better than brake cleaner though. Might consider Isopropal (sp?) Alcohal instead for the majority of your work.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 04-18-2006, 11:45 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Soap and Water
Depending on what you are doing, it's amazing how effective soap and water are. Dawn dishwashing soap works particularly well, I've found.
Mickey Coggins
http://rv8.ch
"Hello, world!"
