Old 04-26-2011, 01:22 PM
ColoCardinal's Avatar
ColoCardinal ColoCardinal is offline
Default Standby Electrical system
I will be installing a secondary electrical system in my RV&a using a BC20 alternator and a VP-X Pro with the secondary buss. I'm considering a solid state Zeftronics as I don't think I need the crowbar overvoltage protection since it is provided by the VP-X. Any recommendations for the best way to put this together would be greatly appreciated. What voltage regulator have you all used?
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
Old 04-26-2011, 09:31 PM
MCA's Avatar
MCA MCA is offline
Carl, Typically the B&C LR-3C is used with the SD-20. It's described in detail in the VP-X install manual.
I don't know much about the Zeftronics but perhaps the folks at B&C can tell you what their past experiences have been.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
